1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75219
Background
The Craftsman 2550 PSI Pressure Washer 580.752190 is a gas-powered machine designed for a variety of cleaning tasks. It is equipped with a 190cc Briggs & Stratton engine and an axial cam pump, providing a maximum pressure of 2550 PSI and a flow rate of 2.3 GPM. Additionally, it incorporates a detergent mixing feature, which uses a siphon hose for the application of soaps and cleaning solutions.
The pressure washer is designed with mobility in mind, featuring 10" wheels and a fold-down handle. A high pressure hose of 25 feet and a spray gun with quick connect spray tips are included, allowing for different spray patterns based on the cleaning task. The axial cam pump incorporates an automatic cool down system, circulating water to prevent overheating when the trigger is not in use.
Technical Specifications
  • Model Number: 580.752190
  • Product Type: Pressure Washer
  • Maximum pressure: 2550 PSI
  • Maximum flow rate: 2.3 GPM
  • Detergent mixing method: Uses included siphon hose
  • Water supply temperature limit: 100°F
  • Engine type: Briggs & Stratton 126T02-0118-B1
  • Engine displacement: 190cc
  • Engine power: 6.5 HP
  • Fuel tank capacity: 1.6 quarts
  • Oil capacity: 18 oz
  • Mobility: 10" wheels and fold-down handle
  • Hose length: 25 foot high pressure hose
  • Spray gun feature: Quick connect spray tips for variable spray patterns
  • Detergent siphon type: PerfectMix siphon for undiluted concentrate or a standard siphon hose and filter for diluted solutions.
  • Pump type: Axial cam pump
  • Pump safety feature: Automatic cool down system to circulate water and prevent overheating if trigger is not pulled for several minutes.
Warranty
The Craftsman Pressure Washer 580.752190 comes with a warranty period of 1 year, safeguarding against any defects that arise due to materials or workmanship. It's important to note that for commercial or rental usage, the warranty period is significantly shorter, lasting only for 90 days from the date of purchase. Claiming the warranty requires reaching out to Sears, as they are the manufacturers and warranty providers for this product. Do remember to keep your proof of purchase safe, as it may be required while claiming the warranty.
Craftsman 580.752190 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 701
