4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752192
Background
The Craftsman Pressure Washer 580.752192 is a gasoline-powered pressure washer designed for residential use. The unit is equipped with a 196cc Briggs & Stratton engine and an axial cam pump that delivers a maximum pressure output of 2550 PSI and a maximum flow rate of 2.3 gallons per minute. The pressure washer includes a steel frame for durability and 10" pneumatic wheels for mobility.
Further features of the Craftsman Pressure Washer 580.752192 include a 25ft high-pressure hose, a spray gun, and four quick-connect spray tips to cater to different cleaning needs. This model also includes an onboard detergent tank which allows the user to use soap or cleaning chemicals alongside water for cleaning. Other technical specifications include a fuel tank capacity of 1.6 quarts and oil capacity of 18 oz. The product weighs 72 lbs and measures 24" x 19" x 37".
Technical Specifications
  • Model Number: 580.752192
  • Product Type: Pressure Washer
  • Engine: 196cc Briggs & Stratton
  • Pump Type: Axial cam pump
  • Maximum Pressure: 2550 PSI
  • Maximum Flow Rate: 2.3 GPM
  • Power Source: Gasoline
  • Fuel Tank Capacity: 1.6 quarts
  • Oil Capacity: 18 oz
  • High Pressure Hose Length: 25 ft
  • Wheel Size: 10" pneumatic
  • Product Weight: 72 lbs
  • Product Dimensions: 24" x 19" x 37"
Warranty
The Craftsman 2550 PSI Pressure Washer (Model 580.752192) comes with a 2-year limited warranty provided through Sears. This warranty covers any defects in the materials or workmanship of the product. However, it does not extend to wear parts or damage that results from improper use of the pressure washer. To claim this warranty, customers should reach out to Sears, providing details of the issue and proof of purchase to validate the product is within the warranty period.
Craftsman 580.752192 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 463
