4 Diagrams
Documents
Models
580.752191
Background
The Craftsman Pressure Washer 580.752191 is a gas-operated cleaning device designed for residential use. Manufactured by Sears, Roebuck and Co., it is employed for cleaning various surfaces such as patios, vehicles, buildings, and equipment.
This pressure washer is equipped with a 190cc Briggs & Stratton 126T02 engine, and an axial cam pump that requires no oil and has a thermal relief mechanism to prevent overheating. The pump provides a maximum pressure of 2550 PSI and flow rate of 2.3 GPM. The device has a fuel tank capacity of 1.6 quarts and an oil capacity of 18 ounces. It also features a 25-foot high-pressure hose, a 35-foot power cord, and four quick-connect spray tips for varying spray patterns and pressure levels. The unit includes a wheeled mobility kit and a fold-down handle for compact storage. The operation of this pressure washer involves connecting a garden hose to the water inlet, adding fuel to the engine, and starting the engine with the recoil starter. Regular maintenance includes managing the engine oil, air filter, spark plug, pump inlet filter, and spray tips.
Technical Specifications
  • Maximum Pressure: 2550 PSI
  • Maximum Flow Rate: 2.3 GPM
  • Engine: Briggs & Stratton 126T02
  • Engine Displacement: 190cc
  • Fuel Tank Capacity: 1.6 Quarts
  • Oil Capacity: 18 Ounces
  • Pump: Axial cam
  • Power Source: Gasoline
  • Weight: 61 lbs
  • Dimensions: 24.5" x 22" x 38"
Warranty
The Craftsman Pressure Washer 580.752191 comes with a 2-year consumer warranty provided by Sears, Roebuck and Co. This warranty covers defects in materials and workmanship, giving owners peace of mind regarding the quality and durability of their product. It's important to note that there are limitations on the warranty for commercial use. In addition to this, the emissions control system of the Pressure Washer is warranted separately by the manufacturer for the same duration of 2 years. To claim the warranty, it's usually required to contact the manufacturer or retailer (in this case, Sears) and provide proof of purchase and details about the defect or issue. Always check the warranty terms and conditions to see what is and isn't covered, and how to make a claim.
Craftsman 580.752191 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 37
All Time: 558
