5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752102
Background
The Craftsman 580.752102 is a gas-powered pressure washer constructed by Sears Brands. With a flow rate of 2.5 gallons per minute and a peak pressure of 2700 PSI, it is designed to handle medium-duty residential cleaning tasks. The pressure washer is powered by a Briggs & Stratton 12R512 190cc engine, with a displacement of 11.57 cu.in. The fuel capacity is 1.6 quarts and the engine's power rating is 6.75 HP. The washer incorporates an aluminum axial cam pump and can output a maximum pressure of 2700 PSI, with a maximum flow rate of 2.5 GPM. Other specifications include a 25 ft high-pressure hose, a 1-gallon detergent tank, and a total weight of 71 lbs.
The pressure washer is equipped with a thermal relief valve and an insulated trigger gun with a safety lock. It also features a nozzle selector with four settings (0o, 25o, 40o, soap). For ease of manoeuvrability, it has 10" flat-free tires and a set of wheels that do not deflate. A handle and storage for accessories are integrated into the design. The operation of the pressure washer involves connecting the high-pressure hose to the pump and the spray gun, attaching a garden hose to the water inlet, adding fuel and engine oil, adjusting the choke and throttle levers, and starting the engine. After use, it is essential to squeeze the trigger to release pressure and engage the gun's safety lock. Regular maintenance includes checking the engine oil level, cleaning the water inlet screen, using pump saver or antifreeze for winter storage, and replacing oil, air filter, and spark plug as per the maintenance schedule. Only original parts from the manufacturer are recommended for replacements.
Technical Specifications
  • Model Number: 580.752102
  • Product Type: Pressure Washer
  • Engine: 12R512 190cc OHV
  • Displacement: 11.57 cu.in
  • Fuel Capacity: 1.6 quarts
  • Power Rating: 6.75 HP
  • Pump: Aluminum axial cam
  • Max Pressure: 2700 PSI
  • Max Flow Rate: 2.5 GPM
  • High Pressure Hose Length: 25 ft
  • Detergent Tank Capacity: 1 gallon
  • Weight: 71 lbs
Warranty
The Craftsman 2700 PSI Pressure Washer 580.752102 comes with a 2 year limited warranty provided by Sears. This warranty covers any defects in materials or workmanship related to the pressure washer. However, it should be noted that wear parts such as nozzles, hoses, and tires are explicitly excluded from the warranty. In order to claim this warranty, it is crucial that users adhere to the maintenance guidelines as detailed in the operator's manual. Failure to do so could potentially void the warranty.
Craftsman 580.752102 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 265
