2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75207, 580.752070
Background
The Craftsman 3000 PSi Pressure Washer, model 580.752070, is a gas-powered pressure washer manufactured by GOLDSTAR for Sears under the Craftsman brand. It is equipped with a 190cc Briggs & Stratton engine and an axial cam pump. This pressure washer can produce up to 3000 PSi (pounds per square inch) of water pressure at a flow rate of 2.7 gallons per minute, making it suitable for a variety of cleaning tasks.
The pressure washer includes features such as a 25 ft high-pressure hose and an onboard 1-gallon detergent tank. It also possesses a multi-nozzle spray gun system and a steel frame with 10-inch wheels for mobility. Weighing 71 lbs, the machine is designed to balance power and portability. The model 580.752070 is primarily used for residential pressure washing tasks, which can include cleaning wood decks, concrete patios, vehicles, and equipment.
Technical Specifications
  • Model Number: 580.752070
  • Product Type: Gas-Powered Pressure Washer
  • Engine: 190cc Briggs & Stratton
  • Maximum Pressure: 3000 PSi
  • Maximum Flow Rate: 2.7 Gallons Per Minute
  • Pump Type: Axial Cam with Thermal Relief Valve
  • Hose Length: 25 Feet High-Pressure Hose
  • Spray Gun System: Multi-Nozzle
  • Detergent Tank Capacity: Onboard 1-Gallon
  • Frame Material: Steel
  • Wheel Size: 10 Inches
  • Weight: 71 lbs
Warranty
The Craftsman 3000 PSi Pressure Washer, model 580.752070, comes with a 1-year limited warranty provided by Sears. This warranty covers any defects in materials and workmanship for a period of 1 year from the date of purchase. It's important to note that the engine of the pressure washer is covered separately under the engine manufacturer's warranty. Be aware that limitations apply for commercial or rental use of the product. To claim the warranty, you would generally need to contact Sears or the engine manufacturer, as appropriate, providing details of the defect along with proof of purchase.
Craftsman 580.752070 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 500
