2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75206
Background
The Craftsman 2500 PSI pressure washer (model 580.752060) is a gasoline-powered pressure washer produced by Sears Brands. It is equipped with a 169 cc Honda GCV160 engine and an axial cam pump, which can deliver up to 2500 PSI of water pressure and a water flow of 2.3 gallons per minute. The machine is portable and has a cart design with 10" pneumatic tires for mobility. It is also equipped with a 20-foot high-pressure hose and a 1-gallon detergent tank. The pressure washer offers four quick connect spray tips (0°, 15°, 25°, 40°) for different cleaning applications.
In terms of maintenance, the engine oil needs to be checked before each use and replaced after the first 5 hours of operation. The air filter should be inspected and cleaned every 25 hours or 3 months, and replaced annually. The spark plug should be replaced every 100 hours or annually. For long term storage, especially in freezing temperatures, the pump should be protected with pump saver or by flushing with RV antifreeze to prevent freeze damage.
Technical Specifications
  • Model Number: 580.752060
  • Product Type: Pressure Washer
  • Engine: 169 cc, 4-stroke OHV, Honda GCV160
  • Maximum Pressure: 2500 PSI
  • Maximum Flow Rate: 2.3 GPM
  • High Pressure Hose Length: 20 ft
  • Detergent Tank Capacity: 1 gallon
  • Fuel Tank Capacity: 0.29 gallons
  • Power Source: Gasoline
  • Pump Type: Axial cam pump with thermal relief valve
  • Dimensions: 17 x 19 x 34 in
  • Weight: 73 lbs
Warranty
The Craftsman pressure washer model 580.752060 comes with a 1-year limited warranty provided by Sears. This warranty covers any defects in materials or workmanship for one year from the date of purchase, provided the washer is used for personal residential purposes. However, note that commercial or rental use is only covered for 90 days. To claim the warranty, you should contact Sears directly, ensuring you have proof of purchase and a description of the defect or issue.
Craftsman 580.752060 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 52
All Time: 971
