No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.751651
Background
The Craftsman Pressure Washer 580.751651 is a pressure washer manufactured by Goldstar for Sears under the Craftsman brand. It is designed to produce a high water pressure, up to 2200 PSI, powered by a 6.5 horsepower engine. This device is capable of outputting water at a flow rate of 3 gallons per minute.
The Craftsman Pressure Washer 580.751651 comes equipped with a variety of features. It can use undiluted detergent with an adjustable ratio up to 73:1, and can operate with a water supply temperature of up to 140°F. Its suction height is 3 feet, and the engine is a GN-Series, 6.5 HP, with 190cc displacement. Other features include a Champion RC12YC spark plug, a gasoline capacity of 1 U.S. gallon, and an oil capacity of 20 oz. The ignition system is a solid state with a 0.0125 inch air gap.
Technical Specifications
  • Product Type: Pressure Washer
  • Manufacturer: Sears, Roebuck and Co.
  • Engine: GN-Series, 6.5 HP, 190cc displacement
  • Pump Pressure: Adjustable up to 2200 PSI
  • Flow Rate: 3 GPM
  • Detergent Mix: Uses undiluted detergent
  • Detergent Ratio: Adjustable up to 73:1
  • Water Supply Temperature Limit: 140°F
  • Suction Height: 3 ft maximum
  • Spark Plug: Champion RC12YC, gap set to 0.030 inches
  • Gasoline Capacity: 1 U.S. gallon
  • Oil Capacity: 20 oz
  • Ignition: Solid state with 0.0125 inch air gap
  • Portability: 10" pneumatic tires and a wire handle
  • Weight: Approximately 60 pounds (dry)
  • Fuel: Regular unleaded gasoline
  • Hose Length: 35 foot high pressure hose
  • Nozzle: Adjustable pressure and spray pattern
  • Detergent System: Onboard tank with adjustable mixing ratio
Warranty
The Craftsman Pressure Washer 580.751651 comes with a warranty that extends for different lengths of time for various components. The overall unit is covered under a one-year consumer warranty. The GN-Series engine, a vital part of the unit, is separately covered under a two-year warranty, provided it is maintained as per the guidelines mentioned in the owner's manual. However, it's important to note that the warranty does not cover normal wear items such as spark plugs, air filters, and hoses. Additionally, the warranty could be deemed void in cases of misuse, improper maintenance, or if the unit is used for commercial or rental purposes.
Craftsman 580.751651 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 497
