No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75151
Background
The Craftsman Pressure Washer 580.751510 is a machine intended for outdoor cleaning tasks. Made by GOLDSTAR for Sears under the Craftsman brand, this pressure washer is designed for residential use. It is equipped with a 5 HP Briggs & Stratton engine and operates with an adjustable pump pressure that can reach up to 1800 psi. The flow rate of the machine is 2.5 gallons per minute, and it has the capability to mix undiluted detergent at a ratio adjustable up to 66:1. The water temperature that it can handle should not exceed 140°F, and it has a maximum suction height of 3 feet.
The Craftsman Pressure Washer 580.751510 has several features that make it functional for its users. The adjustable pressure nozzle allows for high or low pressure spraying, while the onboard detergent tank makes it possible to apply detergents directly. It includes a 25-foot high-pressure hose and a quick-connect fitting for a garden hose. The machine is designed for portability, featuring wheels and a handle. It has a safety latch on the spray gun and a low oil auto shutoff feature for the engine.
Technical Specifications
  • Pump Pressure: Adjustable up to 1800 psi
  • Flow Rate: 2.5 gallons per minute (gpm)
  • Detergent Mix: Undiluted detergent
  • Detergent Ratio: Adjustable up to 66:1
  • Water Supply Temperature: Not to exceed 140°F
  • Suction Height: 3 ft maximum
  • Engine: 5 HP Briggs & Stratton engine
  • Displacement: 12.6 cu in
  • Spark Plug: Champion RCJ8 or equivalent, gap 0.030 in
  • Gasoline Capacity: 2 US quarts
  • Oil Capacity: 20 oz, SAE 30 weight oil recommended
  • Ignition: Solid state with 0.0125 in air gap
  • Features: Adjustable pressure nozzle with settings for high or low pressure spraying, onboard detergent tank for applying detergents, 25 ft high pressure hose, quick connect fitting for garden hose, wheels and handle for portability, safety latch on spray gun, low oil auto shutoff.
Warranty
The Craftsman Pressure Washer 580.751510 comes with a warranty that covers different parts of the product for varying lengths of time. The entire pressure washer is covered for a period of 1 year from the date of purchase. This warranty typically covers defects in materials and workmanship. The gasoline engine, on the other hand, enjoys a longer warranty period of 2 years, which covers the same aspects. To claim the warranty, customers typically need to retain their proof of purchase and contact the manufacturer or authorized service center, detailing the issue they're facing. However, specific procedures can vary, so it's advisable to check the user manual or manufacturer's website for detailed instructions.
Craftsman 580.751510 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 301
