No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.750401
Background
The Craftsman Pressure Washer 580.750401 is a gasoline-powered pressure washer produced by Sears Brands Management Corporation under the Craftsman brand. It is equipped with a 140 cc Briggs & Stratton engine that allows it to reach a pressure of 2,200 PSI, with a flow rate of 1.9 GPM. The pressure washer also includes a 30-foot high-pressure hose, three quick-connect spray tips, and a hose reel for easy storage.
The pressure washer is designed with an integrated Project Pro PerfectMix detergent siphon and an automatic cooling system to prevent overheating. It also comes with a wheeled mobility kit for easy movement and storage. The operation of the pressure washer involves adding oil and gasoline to the engine, connecting the high-pressure hose to the pump outlet and spray gun, and pulling the recoil starter to start the engine. Maintenance includes regular checks and cleaning of the water inlet screen, changing the engine oil, and purging the pump before storage.
Technical Specifications
  • Model Number: 580.750401
  • Product: Pressure Washer
  • Engine: 140 cc Briggs & Stratton 090000 series
  • Displacement: 8.64 in3 (141 cc)
  • Fuel tank capacity: 0.8 quarts
  • Pump: Axial cam pump
  • Pressure rating: 2,200 PSI
  • Flow rate: 1.9 GPM
  • High pressure hose length: 30 ft
  • Power: 5.5 HP
  • Weight: 43 lbs
  • Mobility: Wheeled
  • Cooling system: Automatic
  • Spray tips: 3 quick connect (0°, 25°, soap)
  • Hose connector: Garden hose (female coupler)
Warranty
The Craftsman Pressure Washer 580.750401 comes with a 2-year limited warranty provided by Sears Brands Management Corporation. This warranty coverage is specifically for defects in materials and workmanship. However, it doesn't cover damages resulting from incorrect usage or inadequate maintenance. Alongside, there is a distinct warranty for the emissions control system as per the EPA's regulations. To claim the warranty, one must contact Sears Brands Management Corporation, providing relevant details about the defect.
Craftsman 580.750401 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 643
