Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
900.79952
Background
The Craftsman Hedger 900.79952 is a hedge trimmer designed to assist in the maintenance and shaping of hedges and shrubs. Manufactured by Elu for Sears, it's a part of the Craftsman line of tools and gardening equipment.
The hedger operates on 120 volts and has a current of 2.8 amps, running at a speed of 3100 strokes per minute. It is equipped with a lock button, a switch, and a bail handle for operation. The core components include an armature, a gear case, and a field. The device features a blade and gear system, with the blade designed for cutting through plant material. The gear system is lubricated with BDL 2.0 grease to ensure smooth functioning. The hedger also comes with an identification label and a nameplate.
Technical Specifications
  • Model Number: 900.79952
  • Voltage: 120 Volts
  • Amperage: 2.8 Amps
  • Strokes per Minute: 3100 SPM
  • Cutting Thickness Capacity: 3/4" (19mm) max
Warranty
The Craftsman Hedger 900.79952 comes with a full one-year warranty. This warranty covers any defects in material or workmanship that may occur within one year from the date of purchase. It is important to note that the warranty service only applies if the hedge trimmer is used in the United States. The warranty provides specific legal rights, which may vary from state to state. To claim the warranty, you can return the product to your nearest Sears store or Craftsman outlet. They will replace the product free of charge. For any inquiries or further assistance regarding the warranty, you can contact Sears, Roebuck and Co., Dept. 817WA, Hoffman Estates, IL 60179.
Craftsman 900.79952 Owners Manual
CRAFTSMAN Heavy Duty Hedge Trimmer Instruction Manual
Craftsman Heavy Duty Hedge Trimmer Instruction Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 180
