2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79634, 358.796340
Background
The Craftsman Hedger 358.796340 is a gasoline-powered tool designed for trimming hedges and shrubs. The product is a 2-cycle device powered by a 25 cubic centimeter, or 1.5 cubic inch engine, and boasts a 22-inch blade. Additionally, it features an ON/OFF switch for controlling the engine and a choke to aid in cold starting. The hedger also includes a primer bulb, which removes air from the fuel lines and fills them with fuel, making the engine easier to start. It also has a throttle trigger that controls engine speed.
The product uses a mixture of unleaded gasoline and a good quality synthetic 2-cycle air-cooled engine oil. The mixture ratio is 40:1, meaning 3.2 ounces of oil is mixed with 1 gallon of unleaded gasoline. The product is intended for those who require regular maintenance of hedges and shrubs, offering a precise trimming solution.
Technical Specifications
  • Engine: 25cc/1.5 cu. in. 2-Cycle gasoline engine
  • Blade: 22" double sided hedge trimmer blade
  • Fuel: Unleaded gasoline mixed with synthetic 2-cycle oil at 40:1 ratio
  • Ignition: Electronic ignition system with fixed timing
  • Carburetor: Factory set, may need adjustments for idle speed
  • Muffler: Temperature limiting muffler with spark arresting screen
  • Air Filter: Nylon, clean every 5 hours of use
  • Spark Plug: Needs yearly replacement
  • Fuel Filter: Needs yearly replacement
Warranty
The Craftsman Hedger 358.796340 comes with a one-year full warranty. This warranty covers any defects in material or workmanship, excluding expendable parts such as the spark plug, air filter, and blades. However, for commercial or rental use, the warranty is only valid for 30 days from the date of purchase. Warranty services and repairs can be obtained at Sears Service Centers. It is important to note that the warranty provides specific legal rights that may vary from state to state. Additionally, the engine emissions control system has a separate two-year warranty, which covers parts like the carburetor, ignition system, spark plug, muffler, and fuel tank. Any warranty repairs should be completed within 30 days. It is important to remember that the warranty does not cover any damage resulting from misuse, abuse, improper maintenance, modifications, or the use of unapproved parts. To file a claim under the warranty, you can contact the nearest authorized service center or call Sears at the provided number.
Craftsman 358.796340 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 343
