No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79572
Background
The Craftsman Hedger 358.795720 is a gasoline-powered tool designed for trimming hedges and other vegetation. It is equipped with a 22-inch blade and powered by a 25cc 2-cycle engine. This product is characterized by several functional features, including an on/off switch, a choke lever, a primer bulb, and a throttle trigger. The on/off switch is utilized to stop the engine, the choke lever aids in cold starting by supplying fuel to the engine, the primer bulb removes air from the fuel lines and fills them with fuel, and the throttle trigger controls the engine speed.
The Craftsman Hedger 358.795720 is intended for outdoor use, specifically for landscaping tasks such as trimming and shaping hedges. It uses a mix of unleaded gasoline and 2-cycle air-cooled engine oil for operation. The fuel mixture is achieved by combining 3.2 ounces of oil with 1 gallon of unleaded gasoline. This tool can be beneficial for those who require a convenient and effective solution for maintaining their outdoor spaces.
Technical Specifications
  • Engine Type: 2-cycle gasoline engine
  • Engine Capacity: 25cc/1.5 cu. in.
  • Blade Length: 22 inches
Warranty
The Craftsman Hedger 358.795720 comes with a full one-year warranty. This warranty covers any defects in materials or workmanship, and applies as long as the hedger is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the manual. The warranty excludes expendable parts such as the spark plug, air filter, and blade, which may become worn during normal use. If the hedger is used for commercial purposes, the warranty applies for 90 days from the date of purchase, and if used for rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, you can return the hedger to the nearest Sears store or service center in the United States. It is important to note that this warranty only applies while the product is used in the United States. For more information about your warranty rights and responsibilities, you can contact your nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.795720 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 270
