No Image
This wiki is missing a device image. Help improve this page by uploading one!
16 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88799
Background
The Craftsman Gas Snow Thrower 536.887990 is a snow removal machine powered by a 4-cycle engine. Manufactured by Western Tool & Stamping for Sears under the Craftsman brand, this snow thrower is designed to remove snow and slush efficiently. The snow thrower includes features such as an auger for breaking up and lifting snow, and controls for operating the machine. After each use, it is recommended to run the machine to clear the auger of snow and to prevent freezing of the auger or controls, all snow and slush should be removed from the snow thrower. Regular checks should be made for any loose or damaged parts, and any loose fasteners should be tightened. The functionality of the controls should also be checked regularly.
The Craftsman Gas Snow Thrower operates using chain lubrication and the engine requires oil. It is suggested to adjust the machine after 2 to 4 hours of use for optimal performance. The snow thrower comes with ignition keys, which are essential for starting the engine. The machine's parts are designed to be durable, but if any parts are worn or damaged, immediate replacement is recommended. The snow thrower is designed for use in the winter season, particularly before storage, to ensure the removal of all snow and ice.
Technical Specifications
  • Engine Model Number: 143.029003
  • Displacement: 190cc
  • Bore x Stroke: 63mm x 54mm
  • Ignition: F-021005L
  • Oil Capacity: 600 ml
  • Fuel Capacity: 1.1 L
  • Dry Weight: 34 kg
Craftsman 536.887990 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 1,195
