No Image
This wiki is missing a device image. Help improve this page by uploading one!
16 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.887992
Background
The Craftsman Gas Snow Thrower 536.887992 is a mechanical device designed to remove snow from areas where it is not wanted or needed. It is fueled by gas and operates with a 4-cycle engine, model number 143.049001. Manufactured by Western Tool & Stamping for Sears under the Craftsman brand, it is equipped with a variety of features that aid in the process of snow removal. Notably, it includes ignition keys that are attached to the engine in a plastic bag and a packet of fuel stabilizer.
The use of this gas snow thrower is primarily intended for domestic settings such as driveways and sidewalks, but it can also be used in commercial areas where snow needs to be cleared quickly and efficiently. The device is beneficial in regions where heavy snowfall is common, as it can significantly reduce the time and effort required to clear snow manually. It is designed to throw the snow to a different location, allowing for a clear pathway or area.
Technical Specifications
  • Model Number: 536.887992
  • Product Type: Gas Snow Thrower
  • Displacement: 370C, 358 cc
  • Power Rating: 9 HP, 11 HP
  • Bore x Stroke: 52 mm, 58 mm
Warranty
The warranty period for this product is two years from the date of purchase, provided that the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. If the snow thrower is used for commercial or rental purposes, the warranty period is reduced to 90 days from the date of purchase. The warranty covers any defects in material or workmanship, and Sears will repair any such defects free of charge. However, the warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the owner's manual. To claim the warranty, the Craftsman Snow Thrower should be returned to the nearest Sears Service Center in the United States. It is important to note that the warranty is only valid while the product is in use in the United States.
Craftsman 536.887992 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 35
All Time: 1,274
