No Image
This wiki is missing a device image. Help improve this page by uploading one!
14 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.887752
Background
The Craftsman Gas Snow Thrower 536.887752 is a machine designed to move snow to another location or aside to clear a specific area. It is powered by a 4-cycle engine, model number 12C414-0131-E1, produced by Western Tool & Stamping for Sears under the Craftsman Brand. The machine features various components that contribute to its functionality, including a breather tube, a crankcase gasket, a crankcase cover, an oil seal, an oil fill cap, an intake gasket, a throttle shaft, an idle speed kit, a float hinge pin, a choke valve, a choke shaft, and a main jet.
The snow thrower also has other parts that ensure its operation such as a carburetor overhaul kit, a carburetor spacer, a carburetor itself, a welch plug, a throttle valve, a carburetor float, a needle/seat kit, a float bowl gasket, a hose connector, a governor spring, a control bracket, a governor control lever, a control lever, a control panel, an armature magneto, a magneto armature screw, and a sparkplug terminal. This gas snow thrower is used to efficiently remove snow from driveways, sidewalks or any other outdoor surfaces that need to be cleared during snowy weather.
Technical Specifications
  • Horsepower: 7.75 HP
  • Displacement: 206 cc
  • Gasoline Capacity (unleaded): 4 quarts
  • Oil Capacity: 5W30 (20 oz capacity)
  • Spark Plug: Long life platinum P/N 5066
  • Valve Clearance - Intake: 0.004-0.006 in.
  • Valve Clearance - Exhaust: 0.009-0.011 in.
Warranty
The Craftsman Gas Snow Thrower 536.887752 comes with a limited two-year warranty. This warranty covers any defects in material or workmanship, and Sears will repair the snow thrower free of charge within the warranty period. However, it is important to note that the warranty is valid only if the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions provided in the owner's manual. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence. If you need to claim the warranty, you can do so by returning the Craftsman Snow Thrower to the nearest Sears service center in the United States. It is important to remember that this warranty is only applicable while the product is in use in the United States.
Craftsman 536.887752 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 46
All Time: 969
