No Image
This wiki is missing a device image. Help improve this page by uploading one!
13 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88681
Background
The Craftsman Gas Snow Thrower 536.886811, manufactured by Western Tool & Stamping for Sears, is a four-cycle engine model designed to remove snow. This tool is powered by gas, which is necessary for its operation. Its main features include an auger, a component that collects the snow, and a snow chute deflector that directs the snow to a specific direction.
The machine is equipped with an ignition key for starting, a recoil starter, and various controls for operating the engine and the snow thrower. Additionally, it has an oil cap for checking and adding engine oil, and a primer button to prepare the engine for start-up. The snow thrower also features a handle for easy maneuvering and a headlight for visibility in low-light conditions. It provides a range of adjustability, including for the auger, belts, cable, and carburetor. Various components, such as the auger shaft, hex shaft and gears, and spark plug, require regular maintenance for optimal performance.
Technical Specifications
  • Engine: 8 hp, 19.43 cu. in. displacement
  • Gasoline Capacity: Unleaded, 4 quarts
  • Oil (26 oz. Capacity): 5W-30
  • Spark Plug: Champion RJ19LM (GAP .030 in.)
  • Valve Clearance: Intake: .010 in., Exhaust: .010 in.
Warranty
The document mentions a two-year limited warranty on the Craftsman Gas Snow Thrower 536.886811. According to the warranty, if the snow thrower is maintained, lubricated, and tuned-up as per the instructions in the owner's manual, Sears will repair any defect in material and workmanship free of charge. However, this warranty only applies for two years from the date of purchase. It is important to note that if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover expendable items such as spark plugs, drive belts, and shear pins that become worn during normal use. It also does not cover repairs necessary due to operator abuse or negligence. To claim the warranty, the Craftsman Snow Thrower should be returned to the nearest Sears Service Center/Department in the United States while the product is in use in the country. It is advisable to maintain a record of the serial number and date of purchase for future reference.
Craftsman 536.886811 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 251
