No Image
This wiki is missing a device image. Help improve this page by uploading one!
16 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88654, 536.886540
Background
The Craftsman Gas Snow Thrower model number 536.886540 is a dual-stage snow thrower powered by a 5-horsepower engine. Manufactured by Western Tool & Stamping for Sears under the Craftsman brand, this snow thrower is designed to remove snow from outdoor surfaces.
The product features a 22-inch clearing width and a 120V electric start system, which simplifies the process of starting the machine in cold conditions. It also includes a variety of components such as a cylinder, crankshaft, camshaft, and flywheel, among others. The thrower's dual-stage operation means it utilizes a two-step process to remove and throw snow, making it suitable for handling heavier snowfalls. The Craftsman Gas Snow Thrower is designed for outdoor use, specifically for clearing snow from driveways, walkways, and other similar areas.
Technical Specifications
  • Engine: 2-cycle engine
  • Auger Diameter: 12 inches
  • Clearing Width: 20 inches
  • Forward Speeds: 6
  • Reverse Speeds: 2
  • Skid Height Adjustment: 1/2 inch to 4 inches
  • Chute Deflector Control: Adjustable
  • Traction Drive: Friction wheel system
  • Electric Starter: Optional
  • Fuel: Unleaded gasoline
  • Oil: SAE 30 weight detergent oil
Warranty
The Craftsman Gas Snow Thrower 536.886540 comes with a two-year limited warranty. This warranty covers any defect in material and workmanship for a period of two years from the date of purchase, provided that the snow thrower is maintained, lubricated, and tuned-up according to the instructions in the owner's manual. If the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover expendable items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the owner's manual. To claim the warranty, you can return the Craftsman Snow Thrower to the nearest Sears Service Center/Department in the United States. Please note that this warranty is only valid while the product is in use in the United States.
Craftsman 536.886540 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 536
