No Image
This wiki is missing a device image. Help improve this page by uploading one!
15 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.886261
Background
The Craftsman Gas Snow Thrower 536.886261 is a snow removal machine developed by Western Tool & Stamping for Sears under the Craftsman brand. It is equipped with a 4-cycle engine, designed to assist in the task of clearing snow from driveways, walkways, and other outdoor areas.
The gas snow thrower operates by using its engine to throw snow to another location, thereby clearing the path. It has a check spark plug feature for monitoring its ignition system, a fuel check system to maintain proper fuel levels, and a cable adjustment feature for operational control. The machine should be checked and maintained periodically, including inspections for any loose or damaged parts and maintaining the auger, a crucial component for picking up and throwing snow. The controls should also be checked regularly to ensure correct functioning.
Technical Specifications
  • Model Number: 143.029003
  • Engine Type: 4-Cycle
  • Engine Displacement: 187 cc
  • Bore x Stroke: 70 mm x 69 mm
  • Compression Ratio: 9.0:1
  • Maximum Horsepower: 3.7 hp at 3600 rpm
  • Maximum Torque: 8.7 ft-lbs at 2500 rpm
  • Fuel Tank Capacity: 1.1 L
  • Oil Capacity: 0.6 L
Craftsman 536.886261 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 18
All Time: 695
