No Image
This wiki is missing a device image. Help improve this page by uploading one!
16 Diagrams
Documents
Models
536886260
Background
The Craftsman Gas Snow Thrower 536886260 is a piece of outdoor equipment designed for removing snow. It operates using a four-cycle engine, model number 143.019003, which requires regular checks and maintenance as per the product manual. The engine's components include standard parts such as a carburetor, throttle shaft and lever assembly, throttle return spring, choke shaft and lever assembly, and fuel fitting among others.
The Snow Thrower is equipped with a disc drive plate zerk, which requires lubrication with a high temperature EP Moly grease for smooth operation. The product also includes controls that need to be checked for proper functioning after each use. It is recommended to check for any loose or damaged parts and tighten any loose fasteners after each use. The auger, an integral part of the snow thrower that helps in the removal of snow, also requires regular checks and maintenance.
Technical Specifications
  • Engine Model Number: 143.019003
  • Engine Type: 4-Cycle
  • Drive Type: Single Wheel Drive
  • Tire Pressure: 14-17 pounds
Warranty
The warranty for the Craftsman Gas Snow Thrower 536886260 is a limited two-year warranty. This warranty covers any defects in material or workmanship for two years from the date of purchase, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. It's important to note that this warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. Additionally, repairs necessary due to operator abuse or negligence are not covered by the warranty. To claim the warranty, you can return the Craftsman Snow Thrower to the nearest Craftsman Service Center in the United States. It's worth mentioning that this warranty is only valid while the product is in use in the United States.
Craftsman 536886260 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 37
All Time: 620
