No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.8852
Background
The Craftsman Gas Snow Thrower 536.885200 is a snow removal machine designed and manufactured by Western Tool & Stamping for Sears under the Craftsman Brand. It is a gas-powered tool intended for use in clearing snow from outdoor areas such as driveways, sidewalks, and parking lots. This snow thrower is designed with a variety of features to assist in its operation and maintenance.
The snow thrower has a variety of control and operating symbols that indicate different functions and operations. It includes symbols for fast and slow speeds, engine start and stop, choke on and off, neutral and ignition on and off, throttle, primer button, ignition key, drive clutch, forward and reverse, auger clutch, auger collector engage, electric starter, fuel oil and fuel oil mixture, discharge up, down, left, and right, weight transfer, transmission, lift handle, depress pedal, insert to run, and engage to disengage. Additionally, it has a checklist for pre-operation checks and a lubrication chart. Maintenance tasks include checking engine oil level, changing engine oil, tightening all screws and nuts, checking spark plug, lubricating chute control flange, draining fuel, checking fuel, and checking auger drive cable adjustment.
Technical Specifications
  • Horse Power: 3.8
  • Displacement: 10 cu. in.
  • Fuel Tank Capacity: 1 quart
  • Spark Plug Type: Champion RJ19LM, Gap 0.030
Warranty
The Craftsman Gas Snow Thrower 536.885200 comes with a limited one-year warranty. This warranty covers any defects in material or workmanship and is valid for one year from the date of purchase. To claim the warranty, the snow thrower must be maintained, lubricated, and tuned up according to the operating and maintenance instructions provided in the owner's manual. Sears will repair any covered defects free of charge. However, it's important to note that the warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. Additionally, any repair necessary due to operator abuse or negligence, including bent crankshafts or failure to maintain the equipment as per the owner's manual, is not covered by the warranty. To avail warranty service, the Craftsman Snow Thrower should be returned to the nearest Sears Service Center/Department in the United States. It's important to remember that this warranty only applies while the product is in use in the United States.
Craftsman 536.885200 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 297
