No Image
This wiki is missing a device image. Help improve this page by uploading one!
10 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88521
Background
The Craftsman Gas Snow Thrower 536.885210 is a snow removal machine produced by Western Tool & Stamping for Sears. The product runs on a 2-cycle engine and is designed to help clear snow from outdoor areas such as driveways, sidewalks, and parking lots. Its main features include an ignition switch key to start the engine, an auger control bar to start and stop the auger which propels the snow thrower, a chute control rod to change the direction of snow discharge, and a chute deflector to adjust the distance the snow is thrown.
The snow thrower also includes an electric starter button which allows the machine to be started using a 120V electric starter. A spark plug access panel facilitates spark plug removal, and a primer button injects fuel directly into the carburetor manifold for faster starts in cold weather. The product features a choke control, typically used to start a cold engine, and a recoil starter handle for manual engine starts. The Craftsman Gas Snow Thrower is designed to be maintained regularly for optimal functioning, including regular tightening of screws and nuts, checking of the spark plug and drive belts, and lubrication of the chute control flange. If necessary, fuel is drained before storage.
Technical Specifications
  • Engine Power: 5.0 Horsepower
  • Auger Size: 21 Inches
  • Stage Type: Single Stage
  • Auger Propulsion: Yes
  • Start Method: Electric Start
Warranty
The Craftsman Gas Snow Thrower 536.885210 comes with a limited two-year warranty. This warranty covers any defects in material or workmanship and is valid for two years from the date of purchase, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. It's important to note that the warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins, or any repairs necessary due to operator abuse or negligence. To claim the warranty, you can return the Craftsman Snow Thrower to the nearest Craftsman Service Center/Department in the United States. It's worth mentioning that this warranty is only applicable while the product is in use in the United States.
Craftsman 536.885210 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 461
