No Image
This wiki is missing a device image. Help improve this page by uploading one!
12 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.885214
Background
The Craftsman Gas Snow Thrower 536.885214 is a machine designed for removing snow from outdoor areas. This product is powered by a 2-cycle engine, which facilitates its operation in harsh winter conditions. The snow thrower features several controls and adjustments, including a drive lever, chute deflector, discharge chute, ignition switch key, recoil starter handle, electric starter button, choke control, primer button, and a switch box.
The drive lever controls the start and stop of the auger, the component responsible for picking up and throwing snow. The chute deflector and discharge chute adjust the direction and distance the snow is thrown. The ignition switch key is required to start the engine, while the recoil starter handle offers a manual alternative for starting the machine. The electric starter button is used when utilizing the 120V electric starter. The choke control and primer button aid in starting a cold engine, while the switch box functions as a connection for the electric start power cord. Regular maintenance tasks include checking for loose or damaged parts, tightening loose fasteners, checking and maintaining the auger, and ensuring controls are functioning properly.
Technical Specifications
  • Horse Power: 5
  • Displacement: 8.46 cu, in
  • Fuel Tank Capacity: 1.62 quart
  • Fuel/Oil Mixture Ratio: 40:1 (3.2 ounces of air cooled engine 2-cycle oil per 1 gallon of gasoline)
  • Spark Plug Type: Champion RCJ8Y or equivalent (Gap 0.030)
Warranty
The document mentions a warranty for the Craftsman Gas Snow Thrower 536.885214. The warranty period lasts for two years from the date of purchase, as long as the snow thrower is properly maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. Sears offers free repair of any defects in material or workmanship during the warranty period. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the owner's manual. To claim the warranty, customers can return the Craftsman Snow Thrower to the nearest Sears Service Center in the United States. It's important to note that this warranty is only valid while the product is in use in the United States.
Craftsman 536.885214 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 919
