No Image
This wiki is missing a device image. Help improve this page by uploading one!
6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.885201
Background
The Craftsman Gas Snow Thrower 536.885201 is a snow removal tool designed to clear snow from driveways, sidewalks, and other outdoor areas. This model is powered by a 3.8 horsepower engine and features a 21-inch-wide auger to move snow. The auger clutch allows users to control the auger's operation, while the drive clutch lets the user regulate the snow thrower's forward and reverse movement.
The snow thrower also has a discharge function that can be adjusted to direct the expelled snow to the left, right, up, or down. It has a throttle control to adjust the engine's speed and a primer button for preparing the engine for starting. An ignition key is used to start the engine, which can be switched off using a separate control. The snow thrower requires a fuel and oil mixture for operation. It also features a weight transfer transmission system to optimize its performance.
Technical Specifications
  • Engine Model: 143.023800
  • Starting Method: Electric start
  • Series: 900
  • Discharge Chute: Rotatable
  • Collector: Auger type
  • Drive: Forward and reverse
  • Throttle Control: Present
  • Choke Control: Present
  • Ignition: Key-based
  • Starter: Electric
  • Weight Transfer System: Included
  • Control Type: Pedal controls
Craftsman 536.885201 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 757
