No Image
This wiki is missing a device image. Help improve this page by uploading one!
10 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88435
Background
The Craftsman Gas Snow Thrower 536.884351, manufactured by Western Tool & Stamping for Sears, is a gas-powered machine designed for the purpose of removing snow. The machine uses a 3 horsepower engine with a displacement of 6.0 cubic inches and has a fuel capacity of 1 quart, running on unleaded gasoline. The snow thrower incorporates a fuel/oil mix ratio of 40:1 and is fitted with a Champion RJC8Y or CJ8Y spark plug with a gap of .030 inches.
The snow thrower has several operational controls and features that facilitate its use. It is equipped with an auger control bar that starts and stops the auger, which propels the snow thrower. The machine includes a chute control rod, adjusting the direction of snow discharge, and a chute deflector to modify the snow's throwing distance. The snow thrower also has an ignition switch key for starting the engine, a choke control for starting a cold engine, and a primer button that injects fuel directly into the carburetor manifold for fast starts in cold weather. The engine can be started manually using the recoil starter handle or using the 120 V electric starter button.
Technical Specifications
  • Engine: 3 hp, 6.0 cu. in. displacement, uses unleaded gasoline
  • Fuel/Oil Mix Ratio: 40:1 (3.2 oz of air-cooled engine 2 cycle oil per 1 gal of gas)
  • Spark Plug: Champion RJC8Y or CJ8Y, gap .030 in.
Warranty
The Craftsman Gas Snow Thrower 536.884351 comes with a one-year limited warranty. This warranty covers any defects in material and workmanship if the snow thrower is maintained, lubricated, and tuned-up according to the instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover expendable items such as spark plugs, drive belts, and shear pins that become worn during normal use. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment as instructed in the manual. To claim the warranty, you can return the Craftsman Snow Thrower to the nearest Sears Service Center/Department in the United States. Please note that this warranty is only valid while the product is in use in the United States.
Craftsman 536.884351 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 30
All Time: 474
