No Image
This wiki is missing a device image. Help improve this page by uploading one!
11 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.884351
Background
The Craftsman Gas Snow Thrower 536.884351 is a gas-powered machine designed to remove snow from outdoor spaces. Manufactured by Western Tool & Stamping for Sears under the Craftsman brand, this product is equipped with a 3 horsepower engine and a displacement of 6.0 cubic inches. The fuel capacity is 1 quart, and it operates on a fuel-oil mix ratio of 40:1. The snow thrower uses a Champion RJC8Y or CJ8Y spark plug with a gap of 0.030 inches.
In terms of operation, the Craftsman Gas Snow Thrower 536.884351 features various controls for easy use. The auger control bar starts and stops the auger which propels the snow thrower. The chute control rod and chute deflector change the direction and distance of the snow discharge, respectively. The ignition switch key, choke control, and primer button are utilized to start the engine. The snow thrower can be started manually using the recoil starter handle or using the 120 V electric starter with the electric starter button.
Technical Specifications
  • Horse Power: 3 hp
  • Displacement: 6.0 cu. in.
  • Gasoline Capacity: 1 quart
  • Fuel/Oil Mix Ratio: 40:1 (3.2 oz of air-cooled engine 2 cycle oil per 1 gal of gas)
  • Spark Plug: Champion RJC8Y or CJ8Y (Gap .030 in.)
Warranty
The Craftsman Gas Snow Thrower 536.884351 comes with a one-year limited warranty. This warranty covers any defects in material and workmanship, provided that the snow thrower is maintained, lubricated, and tuned-up according to the instructions in the owner's manual. If the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover expendable items such as spark plugs, drive belts, and shear pins that may become worn during normal use. It also does not cover repairs necessary due to operator abuse or negligence. To claim the warranty, the Craftsman Snow Thrower should be returned to the nearest Sears Service Center/Department in the United States. It's important to note that this warranty applies only while the product is in use in the United States.
Craftsman 536.884351 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 317
