No Image
This wiki is missing a device image. Help improve this page by uploading one!
11 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88155, 536.881550
Background
The Craftsman Gas Snow Thrower 536.881550 is a machine designed to remove snow by directing it through a chute, thus clearing a pathway. Manufactured by Western Tool & Stamping for Sears, this snow thrower operates on a gas engine. This machine is equipped with various controls that regulate its operation. A choke control aids in starting a cold engine, while a primer button injects fuel directly into the carburetor for quick starts in cold weather. The snow thrower's speed shifter lever allows users to select the speed of the machine, with options for both forward and reverse motion.
The machine's crank assembly changes the direction of the snow being thrown, while the chute deflector alters the distance the snow is thrown. The discharge chute adjusts the height and direction of the thrown snow. Additionally, the snow thrower features a height adjust skid which modifies the ground clearance of the auger housing. The Craftsman Gas Snow Thrower 536.881550 also comes with features to protect the machine and prolong its lifespan, such as shear pins which are designed to break if an object becomes lodged in the auger housing to prevent damage.
Technical Specifications
  • Model Number: 536.881550
  • Product: Craftsman Gas Snow Thrower 536.881550
  • Product Type: Gas Snow Thrower
  • Engine Displacement: 206 cc
  • Bore: 68mm (2.677 in.)
  • Stroke: 56mm (2.205 in.)
  • Gasoline Capacity: 3 quarts (unleaded)
  • Oil Capacity: 18 oz, 5W30
  • Spark Plug: Champion RJ19LM (Gap .030 in.) or equivalent
  • Valve Clearance (Intake): 0.004-0.006 in.
  • Valve Clearance (Exhaust): 0.009-0.011 in.
  • Armature Air Gap: 0.010-0.014 in.
Warranty
The document provides information about the warranty for the Craftsman Gas Snow Thrower 536.881550. The warranty coverage applies to engines purchased in California in 1995 and thereafter, used in California, and to certified model year 1997 and later engines purchased and used elsewhere in the United States (and after January 1, 2001 in Canada). The warranty covers the emission control system, which includes parts such as the carburetor, air cleaner, ignition system, muffler, and catalytic converter, as well as connectors and other emission-related assemblies. If a warrantable condition exists, Sears will repair the small off-road engine at no cost to the owner, including diagnosis, parts, and labor. The warranty period is for two years, subject to no abuse, neglect, or improper maintenance of the engine. As the owner, it is important to perform the required maintenance listed in the Operating and Maintenance Instructions. Retaining receipts for maintenance is recommended, but warranty coverage cannot be denied solely for the lack of receipts or failure to ensure the performance of scheduled maintenance. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. In case of any questions regarding warranty rights and responsibilities, owners can contact a Sears Service Representative at 1-800-469-4663.
Craftsman 536.881550 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 35
All Time: 658
