No Image
This wiki is missing a device image. Help improve this page by uploading one!
14 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.88113
Background
The Craftsman Gas Snow Thrower 536.881130 is a product designed to facilitate the removal of snow. This model operates using a gasoline engine, which powers the machine's various functions. The snow thrower includes several features to enhance its operation. Its central components include an auger, which is used to gather and throw snow, a traction drive lever, which propels the machine both forwards and backwards, and a speed shifter lever, which allows the user to select the desired speed of operation.
The device also possesses a crank assembly and a chute deflector, both of which enable the user to control the direction and distance of the thrown snow. An ignition key is used to start the engine, and the engine can also be started manually via a recoil starter handle. The machine includes a choke control, used to start a cold engine, and a primer button, which injects fuel directly into the carburetor for fast starts in cold weather. For discharging snow, the machine comes with a remote chute control lever. The throttle control regulates the engine speed and a toolbox is provided for storing spare parts.
Technical Specifications
  • Engine Power: 11.0 Horsepower
  • Snow Thrower Type: 30 Inch Dual Stage
  • Start Type: 120V Electric Start
  • Snow Gathering and Throwing Mechanism: Auger and Impeller
  • Speed Options: 6 Forward Speeds and 2 Reverse Speeds
  • Snow Discharge Controls: Directional and Height Controls
  • Start Options: Recoil and Electric Start
  • Fuel and Oil Requirements: Specific Recommendations
Warranty
The Craftsman Gas Snow Thrower 536.881130 comes with a limited two-year warranty. This warranty covers any defects in material or workmanship for a period of two years from the date of purchase. To claim the warranty, the snow thrower must be maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. It is important to note that if the snow thrower is used for commercial or rental purposes, the warranty will only apply for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the owner's manual. Warranty service can be obtained by returning the snow thrower to the nearest Craftsman service center or department in the United States. The warranty applies only while the product is in use in the United States. It is important to keep in mind that this warranty provides specific legal rights and additional rights may vary from state to state.
Craftsman 536.881130 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 423
