4 Diagrams
Documents
Models
247.889702
Background
The Craftsman Gas Snow Thrower 247.889702 is a gas-powered snow thrower designed to remove snow from driveways, walkways, and other paved surfaces. Manufactured by Modern Tool and Die (MTD) for Sears under the Craftsman brand, this machine is equipped with features that allow it to effectively clear snow.
The gas snow thrower operates by using an engine that rotates internal blades to scoop up and throw snow out of its discharge opening. The engine oil type needed is 5W-30, with an engine oil capacity of 20 ounces. For ignition, it utilizes a Torch F6RTC spark plug with a gap size ranging from .020" to .030". Its fuel capacity is measured at 2.3 quarts which provide sufficient power for the machine to perform its function.
Technical Specifications
  • Engine Oil Type: 5W-30
  • Engine Oil Capacity: 20 ounces
  • Fuel Capacity: 2.3 Quarts
  • Spark Plug: Torch F6RTC
  • Spark Plug Gap: .020" to .030"
Warranty
The Craftsman Gas Snow Thrower 247.889702 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship. If the product is found to be defective, it will be repaired or replaced free of charge, depending on the availability of repair services. However, it is important to note that the warranty is void if the product is used for commercial services or rented to another person. To claim the warranty, you can visit the website www.craftsman.com for more details on warranty coverage and how to obtain repair or replacement. It is worth mentioning that the warranty only covers defects in material and workmanship and does not include expendable items that can wear out within the warranty period, standard maintenance servicing, tire replacement or repair caused by punctures, repairs due to operator abuse or negligence, engine cleaning or repairs caused by fuel contamination, and normal deterioration and wear of exterior finishes.
Craftsman 247.889702 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 676
