10 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.889571
Background
The Craftsman Gas Snow Thrower 247.889571 is a machine designed to help with snow removal. Manufactured by MTD for Sears under the Craftsman brand, this product is powered by gasoline and has a fuel capacity of 2.3 quarts. It uses a 5W-30 type engine oil with a capacity of 20 ounces. The snow thrower operates using a spark plug of type F6RTC, with a gap ranging from .020" to .030".
The snow thrower's function is to pick up snow and throw it out of the way, making paths and areas accessible during snowy weather. It works by using rotating blades inside an auger/impeller housing assembly to capture the snow, then discharging it through a chute. The machine is designed to be used outdoors and is particularly useful in areas where heavy snowfall is common.
Technical Specifications
  • Engine Type: 4-cycle OHV
  • Engine Displacement: 208 cc
  • Electric Start: 120V
  • Fuel Tank Capacity: 2.3 Quarts
  • Oil Type: 5W-30
  • Oil Capacity: 20 ounces
  • Spark Plug: F6RTC (951-10292)
  • Spark Plug Gap: 0.020" to 0.030"
Warranty
The Craftsman Gas Snow Thrower 247.889571 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship. If the product is found to be defective, it will receive free repair or replacement, depending on availability. However, the warranty is void if the product is used for commercial services or rented to another person. To claim the warranty, customers can visit the website www.craftsman.com for coverage details and to obtain repair or replacement. It is important to note that the warranty only covers defects in material and workmanship and does not include expendable items, standard maintenance servicing, tire replacement or repair caused by punctures, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated fuel, or normal deterioration and wear of exterior finishes. Customers should record the model number, serial number, and date of purchase for reference.
Craftsman 247.889571 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,052
