No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.888301
Background
The Craftsman Gas Snow Thrower 247.888301 is a machine designed to remove snow by throwing it out of the way. It is powered by gasoline, which fuels the engine that drives the throwing mechanism. This snow thrower has a model 483-SUA engine, which was manufactured by MTD (Modern Tool and Die) for Sears under the Craftsman Brand. The engine has a capacity for 37 ounces of oil and approximately 5 quarts of fuel. The spark plug used in this model is F6RTC with a gap range of .020" to .030".
The snow thrower is utilized for clearing snow from areas such as driveways, sidewalks, and other outdoor spaces. It works by taking in snow through an inlet, then a rotating mechanism inside the machine throws the snow out through a chute. This process is repeated as the machine is pushed or driven across the snow-covered area. The Craftsman Gas Snow Thrower 247.888301 is thus a useful tool in areas with frequent and heavy snowfall, offering an efficient way to keep pathways clear during the winter.
Technical Specifications
  • Model Number: 247.888301
  • Product Type: Gas Snow Thrower
  • Engine Oil Type: SAE5W-30
  • Engine Oil Capacity: 37 ounces
  • Fuel Capacity: Approx. 5 Quarts
  • Spark Plug: F6RTC
  • Spark Plug Gap: .020" to .030"
Warranty
The Craftsman Gas Snow Thrower 247.888301 comes with a two-year full warranty. This warranty covers any defects in material or workmanship for a period of two years from the date of purchase. If any product is found to be defective, it will be repaired or replaced free of charge, depending on the availability of repair services. However, if the product is used for commercial services or rented to another person, the warranty coverage is limited to one year from the date of purchase. To claim the warranty, customers can visit the website www.craftsman.com for more details on repair or replacement. It is important to note that the warranty only covers defects in material and workmanship and does not include expendable items that can wear out from normal use within the warranty period or standard maintenance servicing. Additionally, tire or wheel replacement or repair resulting from normal wear, accidents, improper operation or maintenance, and repairs necessary due to operator abuse or negligence are not covered under the warranty.
Craftsman 247.888301 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 27
All Time: 570
