5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.88791
Background
The Craftsman Gas Snow Thrower 247.887910 is an outdoor equipment designed to clear snow from driveways, sidewalks, and other surfaces. It is a product of MTD (Modern Tool and Die) made for Sears under the Craftsman brand.
The snow thrower operates by using rotating blades and an auger to pick up and throw snow out of its path. It is powered by gasoline and includes an electric starter for easy ignition. The machine also features specific emissions standards set by the California Air Resources Board (CARB) and United States Environmental Protection Agency (USEPA), ensuring it meets certain levels of environmental efficiency. The snow thrower also utilizes various systems such as a fuel metering system, an air induction system, an ignition system, an exhaust system, and an evaporative control system for its overall operation.
Technical Specifications
  • Model Number: 247.887910
  • Product Type: Gas Snow Thrower
  • Air Index: Lower number indicates cleaner engine
Warranty
The warranty for the Craftsman Gas Snow Thrower 247.887910 is valid for two years from the date of purchase. This warranty covers any defects in material or workmanship. If there is a defect within the warranty period, customers can call 1-800-4-MY-HOME (1-800-469-4663) to arrange for free in-home repair or replacement if repair is not possible. However, it is important to note that the warranty only applies for 90 days if the snow thrower is used for commercial or rental purposes. The warranty does not cover expendable items that become worn during normal use, standard maintenance servicing, tire replacement or repair caused by punctures or wear, repairs due to operator abuse or negligence, engine cleaning or repairs caused by contaminated fuel, or normal deterioration and wear of exterior finishes.
Craftsman 247.887910 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 445
