3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.8878
Background
The Craftsman Gas Snow Thrower 247.887800 is a product designed to assist in snow removal. It is manufactured by MTD (Modern Tool and Die) for Sears under the Craftsman brand. This machine is powered by gas and is designed to pick up and throw snow to clear driveways, sidewalks and other areas.
The snow thrower features a rotating blade system, which includes both an inlet and discharge opening to facilitate the intake and expulsion of snow. It also includes an auger/impeller housing and chute assembly which play key roles in the operation of the machine. The machine also has an engine with electric start capability. The snow thrower comes with a fuel capacity of 2 quarts and an engine oil capacity of 20 ounces. It uses an F6RTC spark plug with a gap of .020"-.030". This product is also designed to be compliant with California Air Resources Board (CARB) Tier 2 Emission Standards.
Technical Specifications
  • Model Number: 247.887800
  • Product Type: Gas Snow Thrower
  • Emissions Durability Period: Moderate (125 hours), Intermediate (250 hours), or Extended (500 hours)
  • Air Index: Lower number indicates cleaner engine
  • Emissions Compliance Period (for engines <225 cc displacement): Category C=125 hours, B=250 hours, A=500 hours
  • Emissions Compliance Period (for engines ≥225 cc displacement): Category C=250 hours, B=500 hours, A=1000 hours
Warranty
The Craftsman Gas Snow Thrower 247.887800 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship. If a defective product is found, it will receive free repair or free replacement if repair is unavailable. However, it's important to note that this warranty is void if the product is used for commercial services or rented to another person. The warranty coverage does not include expendable items that can wear out from normal use within the warranty period, such as augers, auger paddles, drift cutters, skid shoes, shave plate, shear pins, spark plug, air cleaner, belts, and oil filter. It also does not cover standard maintenance servicing, oil changes, tune-ups, tire replacement or repair caused by punctures from outside objects, tire or wheel replacement or repair resulting from normal wear, accidents, improper operation or maintenance, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated or oxidized fuel, normal deterioration and wear of exterior finishes, or product label replacement. To claim the warranty, you can visit the website www.craftsman.com for more details on warranty coverage and how to obtain repair or replacement.
Craftsman 247.887800 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 1,065
