2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.88782
Background
The Craftsman Gas Snow Thrower 247.887820 is a snow removal tool that is powered by gasoline. The product is designed to assist in the removal of snow by throwing it out of the way, thus allowing for clear and accessible paths during the winter months. Manufactured by MTD (Modern Tool and Die) for Sears under the Craftsman brand, it utilizes a rotating blade technology to efficiently remove snow from desired areas.
The Snow Thrower has a fuel capacity of two quarts and an engine oil capacity of 20 ounces. It is equipped with a spark plug of type F6RTC, with an advised spark plug gap of .020"-.030". The product is intended for outdoor use and is primarily utilized in areas that experience heavy snowfall. Some parts of the Snow Thrower, such as the augers, auger paddles, drift cutters, skid shoes, shave plate, shear pins, spark plug, air cleaner, belts, and oil filter, are considered as expendable items and can wear out from normal use.
Technical Specifications
  • Engine Type: 4-cycle OHV
  • Engine Displacement: 243 cc
  • Electric Starter: Yes
  • Drive Type: Self-propelled, 6 forward speeds, 2 reverse speeds
  • Clearing Width: 24 in
  • Intake Height: 21 in
  • Throw Distance: Up to 55 ft
  • Skid Shoes: Yes
  • Headlight: Yes
  • Heated Grips: Yes
  • Chute Control: 180° electric chute control
  • Deflector: Up to 10 in height adjustment
Warranty
The Craftsman Gas Snow Thrower 247.887820 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship. If a defective product is found within the warranty period, it will be repaired or replaced free of charge, depending on the availability of repair services. However, please note that this warranty is void if the product is used for commercial services or rented to another person. To claim the warranty, you can visit the website www.craftsman.com for more details on warranty coverage and how to obtain repair or replacement. It's important to note that the warranty only covers defects in material and workmanship and does not include expendable items that can wear out from normal use within the warranty period, standard maintenance servicing, tire replacement or repair caused by punctures from outside objects, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated or oxidized fuel, or normal deterioration and wear of exterior finishes or product labels.
Craftsman 247.887820 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 26
All Time: 424
