Up to 20% off select tools
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.88694
Background
The Craftsman Gas Snow Thrower 247.886940 is a snow removal machine that is designed to clear snow from outdoor surfaces such as driveways and walkways. It is powered by unleaded gasoline and its engine is fueled by 5W-30 engine oil. The snow thrower has a 26-inch clearing width, making it suitable for handling moderate to heavy snowfall.
This product is manufactured by Modern Tool and Die (MTD) for Sears under the Craftsman brand. Its primary function is to pick up snow from the ground and throw it out of the way, thereby clearing a path. It accomplishes this through the use of rotating blades, which scoop up the snow, and an auger/impeller housing and chute assembly, which direct the snow out of the machine.
Technical Specifications
  • Engine: Craftsman
  • Fuel: Unleaded Gasoline
  • Engine Oil: 5W-30
  • Model Number: 247.886940
Warranty
The Craftsman Gas Snow Thrower 247.886940 comes with a warranty that lasts for two years from the date of purchase. This warranty covers any defects in material or workmanship. If the product is found to be defective and you have proof of purchase, you can either get it repaired or replaced for free, depending on the option chosen by the seller. Additionally, after the second year from the date of purchase, the upper and lower chute of the snow thrower are covered by an additional lifetime limited warranty. This warranty also covers any defects in material or workmanship, as verified by a Sears authorized service provider. With proof of purchase, you are entitled to a new chute free of charge, but you will be responsible for the labor cost of installation and any other costs incurred to verify the defect. To claim the warranty and obtain free repair or replacement, you can visit the web page www.craftsman.com/warranty. It's important to note that the warranty only covers defects in material and workmanship and does not include expendable items, standard maintenance servicing, tire replacement or repair caused by punctures, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated fuel, or normal wear and tear of the exterior finishes. The warranty will be void if the product is used for commercial services or rented to another person.
Craftsman 247.886940 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 66
All Time: 1,188
