2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.883971
Background
The Craftsman Gas Snow Thrower 247.883971 is a gas-powered snow removal tool. The product is designed to streamline the process of snow removal in outdoor spaces such as driveways, sidewalks, and paths. It operates by using a rotating auger to scoop up snow and an impeller to throw the snow out of the discharge chute. The speed of the machine and the direction of snow throw can be controlled with various levers on the handle panel.
The machine is also equipped with a choke control, located on the rear of the engine, which aids in starting the engine. A key must be inserted into the ignition for the engine to start. The engine has a fuel capacity of approximately 5 quarts and uses 5W-30 engine oil. The machine operates on six forward speeds and two reverse speeds, allowing for control over the ground speed and direction of travel. Additionally, the machine includes a headlight for improved visibility during operation.
Technical Specifications
  • Engine Type: 4-cycle OHV
  • Engine Displacement: 208 cc
  • Electric Start: 120V push button start
  • Forward Speeds: 6
  • Reverse Speeds: 2
  • Auger: 12" diameter, 2 blade curved auger
  • Clearing Width: 20"
  • Throwing Distance: Up to 30 feet
  • Skid Shoe: Yes
  • Chute Rotation: 180° electric rotation control
  • Headlight: Yes
  • Tire Size: 16" x 4.8"
Warranty
The Craftsman Gas Snow Thrower 247.883971 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship, and a defective product will receive free repair or replacement if repair is unavailable. It is important to note that the warranty only covers defects in material and workmanship and does not include expendable items that can wear out within the warranty period, standard maintenance servicing, tire replacement or repair caused by punctures, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated fuel, or normal deterioration and wear of exterior finishes. To claim the warranty, customers need to visit the website www.craftsman.com for warranty coverage details and to obtain free repair or replacement. It is also worth mentioning that the warranty is void if the product is used for commercial services or rented to another person.
Craftsman 247.883971 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 286
