Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.88198
Background
The Craftsman Gas Snow Thrower with the model number 247.881980 is a snow removal equipment manufactured by MTD for Sears under the Craftsman Brand. The primary function of this product is to clear snow from pathways, driveways, and other outdoor spaces. The snow thrower is powered by gasoline and has an oil capacity of 20 ounces. It uses Unleaded Gasoline as fuel with a fuel capacity of 2.3 quarts. The device also includes an F6RTC spark plug, which is a critical component in the ignition system, responsible for igniting the fuel-air mixture in the engine's cylinders. This snow thrower is designed with the ability to pick up and throw snow, effectively clearing an area.
The model under discussion has features such as a rotating blade that facilitates the collection and expulsion of snow. It is also equipped with an engine that generates power needed to perform its functions. Besides, the snow thrower's design includes an inlet and discharge openings where snow enters and exits the machine. The operation of this gas snow thrower involves starting an engine, and it's worth noting that the machine can adjust to outdoor temperatures before starting to clear snow. Furthermore, the Craftsman Gas Snow Thrower 247.881980 has a spark plug gap of 0.020” to 0.030”, aiding in the effective ignition of the fuel.
Technical Specifications
  • Model Number: 247.881980
  • Product Type: Gas Snow Thrower
  • Engine Oil: 5W-30
  • Oil Capacity: 20 ounces
  • Fuel: Unleaded Gasoline
  • Fuel Capacity: 2.3 quarts
  • Spark Plug: F6RTC
  • Spark Plug Gap: 0.020” to 0.030”
Warranty
The Craftsman Gas Snow Thrower 247.881980 comes with a limited warranty for a duration of two years from the date of sale. This warranty covers defects in material or workmanship. To claim the warranty, you must provide proof of purchase. In case of a defective product, you have the option to receive free repair or replacement, as determined by the seller. To obtain free repair or replacement, you can visit the web page www.craftsman.com/warranty for further details. It's important to note that the warranty only covers defects in material and workmanship and does not include expendable items that may wear out within the warranty period, standard maintenance servicing, tire replacement or repair caused by external objects, repairs due to operator abuse or negligence, engine cleaning or repairs caused by contaminated fuel, normal deterioration or wear of exterior finishes, or product label replacement. The warranty is void if the product is used for commercial purposes or rented to another person. Sears Brands Management Corporation, located in Hoffman Estates, IL, is responsible for the warranty.
Craftsman 247.881980 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 59
All Time: 1,495
