Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
900.79654
Background
The Craftsman Edger 900.79654 is a landscaping tool designed for the purpose of creating boundaries in outdoor spaces. Manufactured by Elu for Sears under the Craftsman brand, the primary function of this product is to create clean lines and define edges between areas of different materials or uses, such as between a lawn and a garden bed, or between a walkway and a lawn.
The Edger features several components that facilitate its function. The cord retainer is designed to keep the power cord out of the way during operation. The trigger, when engaged, activates the edger and allows it to perform its function. The height adjustment feature allows users to modify the depth at which the edger cuts into the ground, providing flexibility in terms of the appearance and depth of the edges being created. The guard is designed to protect the user from debris during operation. The edge guide helps to ensure straight and precise edges, while the blade is the part of the edger that cuts into the ground to create edges.
Technical Specifications
  • Model Number: 900.79654
  • Product: Craftsman Edger 900.79654
  • Product Type: Edger
  • Motor: Not specified
  • Power Source: Electric
  • Amps: Up to 16A
  • Voltage: 120VAC
  • Blade: Included
  • Cutting Depth Adjustment: Height adjustment lever
  • Handle: Main handle and trigger handle
  • Guard: Included
  • Weight: Not specified
  • Dimensions: Not specified
Warranty
The Craftsman Edger 900.79654 comes with a full one-year warranty. This warranty covers any defects in material or workmanship that may occur within one year from the date of purchase. If the product fails due to such defects, you can have it replaced free of charge by returning it to your nearest Sears store or Craftsman outlet. It's important to note that this warranty is only valid when the edger is used in the United States. To claim the warranty, simply bring the defective product along with proof of purchase to the designated store. Sears, Roebuck and Co. is responsible for handling warranty claims and can be reached at Dept. 817WA, Hoffman Estates, IL 60179.
Craftsman 900.79654 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 31
All Time: 429
