Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79745
Background
The Craftsman Edger 358.797450 is a gasoline-powered lawn care tool manufactured by Poulan/Weedeater for Sears under the Craftsman brand. It operates on a 1.3 cubic inch/21cc 2-cycle engine, which drives the edger's blade. The blade is designed for cutting sod, and its depth can be adjusted using a built-in depth control lever. The Craftsman Edger 358.797450 also features a throttle trigger for controlling engine speed, and an on/off switch for easy operation.
The edger is equipped with a primer bulb that introduces fuel to the carburetor, making it easier to start the engine. It also has a fuel/oil mix cap for refueling and an air inlet for cooling the engine. The unit's handle is divided into an upper and lower segment, connected by a coupling/shaft, and fitted with a starter rope for manual engine starting. The edger also comes with a spark plug, a blade guard and a depth adjusting wheel that lifts the blade out of the cut when the unit is not in use.
Technical Specifications
  • Model Number: 358.797450
  • Engine: 1.3 cu. in./21cc 2-CYCLE Gasoline Engine
  • Fuel/Oil Mix Cap: Yes
  • Starter Rope Handle: Yes
  • On/Off Switch: Yes
  • Choke: Yes
  • Primer Bulb: Yes
  • Throttle Trigger: Yes
  • Blade: Yes
  • Depth Adjusting Wheel: Yes
  • Depth Control Lever: Yes
  • Air Inlet Holes: Yes
  • Muffler and Guard: Yes
  • Spark Plug: Yes
  • Fuel Filter: Yes
  • Serial Number and Starting Instructions: Yes
Warranty
The document does not mention any specific details about the warranty or how to claim it.
Craftsman 358.797450 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 539
