2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3817
Background
The Craftsman Chain Saw 358.381700, manufactured by Poulan/WeedEater for Sears, is a 2-cycle gas-powered chain saw designed for a range of cutting tasks. It features a 23 cubic inch (38cc) engine and a 16-inch bar for cutting. The engine is certified to be emission compliant, which makes it environmentally friendly. The chain saw is equipped with various controls and adjustments for optimal operation.
The chain saw uses a combination of choke and fast idle lever for cold starting or after refuelling. The choke provides additional fuel to the engine during cold start-ups. A primer bulb is incorporated into the design to circulate fuel to the carburetor, providing quicker starting. The chain saw also includes throttle trigger, which controls engine speed, and throttle lock-out, a feature that prevents accidental triggering. Additionally, the chain saw has a chain brake designed to stop the chain in case of kickback, enhancing its operational efficiency. The chain tension can be checked and adjusted as necessary for optimal performance.
Technical Specifications
  • Engine/Motor: 2.3 cu. in. (38cc) 2-cycle gasoline engine
  • Bar Length: 16 in. bar
  • Fuel Type: Gasoline fuel mix
  • Ignition: Electronic ignition system
Warranty
The Craftsman Chain Saw 358.381700 comes with a two-year full warranty, starting from the date of purchase. This warranty covers any defects in material or workmanship, and if a defective product is found, it will receive free repair or replacement, provided that repair is available. Additionally, there is an additional limited warranty on the engine crankshaft, which covers defects in material or workmanship for the third through tenth year from the date of purchase. With proof of purchase, a defective engine crankshaft will be replaced, but the labor cost of crankshaft installation must be paid by the customer. To claim the warranty and obtain free repair or replacement, customers can visit the website www.craftsman.com. It is important to note that the warranty does not cover expendable items that can wear out within the warranty period, product damage caused by user attempts at modification or repair, repairs due to accidents or failure to operate or maintain the product according to instructions, preventive maintenance, or repairs necessary due to improper fuel type or mixture. The warranty is void if the product is used for commercial services or rented to another person. Sears Brands Management Corporation, located in Hoffman Estates, IL, is responsible for the warranty.
Craftsman 358.381700 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 626
