3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.36218
Background
The Craftsman Chain Saw 358.362180 is a gasoline-powered tool manufactured by Poulan/WeedEater for Sears under the Craftsman brand. It has a bar and chain that require continuous lubrication, provided by an automatic chain oiler. Its engine runs on a fuel mix of unleaded gasoline and synthetic 2-cycle air-cooled engine oil at a ratio of 40:1. The chain saw uses approximately one tank of bar oil for every tank of fuel mix.
This chain saw has various controls and features including an ON/STOP switch for engine control, a throttle trigger to control engine speed and a throttle lock-out that must be pressed before the throttle trigger can be squeezed. It also features a choke/fast idle lever used for cold starting or after refueling, and a chain brake designed to stop the chain in case of kickbacks. The chain brake can be activated automatically or manually. The chain tension on this saw is adjustable and should be checked frequently, especially during the first 15 minutes of operation with a new chain.
Technical Specifications
  • Model Number: 358.362180
  • Product Type: Chain Saw
  • Engine Type: 2.4 cu.in./40cc 2-Cycle
  • Bar Length: 18 in.
  • Fuel Type: Gasoline
Warranty
The warranty for the Craftsman Chain Saw 358.362180 is valid for three (3) years from the date of purchase if the product is used and maintained according to the operator's manual. If the product fails due to a defect in material or workmanship within this period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair proves impossible. However, please note that this warranty only applies for one year if the product is used for commercial or rental purposes. The warranty covers only defects in material and workmanship and does not cover expendable items such as bars, chains, filters, or spark plugs, which can wear out from normal use within the warranty period. Repairs necessary due to accidents, failure to operate or maintain the product according to instructions, preventive maintenance, or improper fuel mixture are also not covered by the warranty. To claim the warranty, you should contact your nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be provided at all Sears Service Centers.
Craftsman 358.362180 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 385
