No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.36036
Background
The Craftsman Chain Saw 358.360360 is a gasoline-powered tool primarily used for cutting wood. Made by Poulan/Weedeater for Sears, the chainsaw features a 2.2 cubic inch, 36cc, 2-cycle engine, and comes with a 16-inch bar. It is designed for occasional use and is equipped with various controls and adjustments meant to optimize its operation.
The chainsaw's features include an on/off switch for stopping the engine, a throttle trigger for controlling engine speed, and a throttle lock-out that prevents accidental trigger activation. It also has a choke/fast idle lever that aids in cold starting or after refuelling by providing additional fuel to the engine. To facilitate quicker starting, the chainsaw includes a primer bulb that circulates fuel to the carburetor. Safety-wise, the chainsaw comes with a chain brake that stops the chain in case of kickback, and can be activated manually or automatically. The chainsaw's chain tension can be adjusted as necessary, especially after the first 15 minutes of operation where chain stretching is normal.
Technical Specifications
  • Model Number: 358.360360
  • Product Type: Chain Saw
  • Engine: 2.2 cu.in./36cc 2-Cycle Gasoline
  • Bar length: 16 in.
Warranty
The warranty for the Craftsman Chain Saw 358.360360 is a full one-year warranty. Within this period, if the saw is maintained, lubricated, and tuned up according to the instruction manual, Sears will repair any defect in material or workmanship free of charge. However, it should be noted that the warranty excludes the bar, chain, spark plug, and air filter, as these parts are considered expendable and may become worn during normal use. If the saw is used for commercial or rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, individuals can return the chain saw to the nearest Sears store or service center in the United States. It is important to remember that always disconnecting the spark plug wire when making repairs, except for carburetor adjustments, is crucial to ensure safety. The proper use of personal protective gear, such as steel-toed safety footwear, snug-fitting clothing, non-slip gloves, eye protection, a safety hard hat, and sound barriers, is highly recommended to prevent accidents and injuries.
Craftsman 358.360360 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 600
