No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.360131
Background
The Craftsman Chain Saw 358.360131 is a gasoline-powered tool designed for cutting wood. It is manufactured by Poulan/Weedeater for Sears under the Craftsman brand. This chain saw operates with a 2.4 cubic inch/40cc 2-cycle engine and features an 18-inch bar for cutting. It is equipped with an ON/STOP switch for engine control, a throttle trigger to regulate the engine speed, and a throttle lockout to prevent accidental triggering. It also has a choke/fast idle lever for cold starting or after refueling, which provides additional fuel to the engine.
The chain saw includes a primer bulb that circulates fuel to the carburetor for quicker starting. It is equipped with a chain brake, a device designed to stop the chain if kickback occurs. The chain brake activates either automatically in the event of a kickback or manually if the front hand guard is pushed forward. The chain saw also has an adjusting screw for chain tension. Regular use of the chain saw can cause the chain to stretch, and the tension should be checked regularly. The saw uses bar and chain oil for continuous lubrication during operation. The saw's design requires the use of unleaded gasoline mixed with a good quality synthetic 2-cycle air-cooled engine oil.
Technical Specifications
  • Model Number: 358.360131
  • Product: Craftsman Chain Saw 358.360131
  • Product Type: Chain Saw
  • Engine Type: 2.4 cu.in./40cc 2-Cycle Gasoline Engine
  • Bar Length: 18 in.
Warranty
The Craftsman Chain Saw 358.360131 comes with a full one-year warranty on all parts. During this time, Sears will repair any defect in material or workmanship free of charge, as long as the chainsaw is maintained, lubricated, and tuned up according to the instruction manual. However, please note that the warranty does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that may become worn during normal use. If the chainsaw is used for commercial or rental purposes, the warranty only applies for 30 days from the date of purchase. To claim the warranty, simply return the chainsaw to the nearest Sears store or service center in the United States. It is important to keep in mind that this warranty gives you specific legal rights, and you may also have other rights that may vary from state to state. For more information about your warranty rights and responsibilities, you can contact your nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.360131 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 413
