No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.36012
Background
The Craftsman Chain Saw 358.360120 is a gas-powered saw manufactured by Poulan/Weedeater for Sears. This chainsaw, engineered for cutting wood, is equipped with several key features that aid in its operation and efficiency. It has an ON/STOP switch, which is used to stop the engine, and a PRIMER BULB that circulates fuel to the carburetor for quicker starting. One of the primary features of the Craftsman Chain Saw is the CHAIN BRAKE, designed to stop the chain in the event of a kickback. It also includes a THROTTLE TRIGGER that controls engine speed, and a THROTTLE LOCKOUT that needs to be pressed before the throttle trigger can be squeezed, preventing accidental activation.
The chainsaw also contains a CHOKE/FAST IDLE LEVER, which helps in cold or refueled starting by providing additional fuel to the engine. Another feature is the chain tensioning system. It is normal for a chainsaw chain to stretch during use, especially during the initial operation, and this feature allows you to adjust the chain tension as needed. The unit also has a fuel and oil tank, with the oil tank designed for guide bar and chain oil. For maintenance, the chainsaw is designed for easy cleaning of the air filter and spark arresting screen, and it allows for spark plug replacement.
Technical Specifications
  • Model Number: 358.360120
  • Product Type: Craftsman Chain Saw
  • Spark Arresting Screen: Equipped
  • Chain Brake: Required for commercial logging
  • Assembly: Fully assembled
  • Fuel: Gasoline
  • Engine Type: 2-cycle engine
  • Bar Length: 16 inches
  • Air Filter: Cleanable and replaceable
  • Spark Plug: Champion CJ-7Y
  • Muffler: Equipped with a temperature limiting feature
  • Safety Standards: Listed by Underwriters Laboratories, Inc. in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-2000)
  • Additional Contents: Bartool, 2-cycle engine oil, Carrying case, Hearing protection, Gloves
Warranty
The warranty period for the Craftsman Chain Saw 358.360120 is two years from the initial date of purchase. The warranty covers any warranted part that is scheduled for replacement as required maintenance up to the first scheduled replacement point for that part. The owner will not be charged for diagnostic labor that leads to the determination of a defective warranted part if the diagnostic work is performed at an approved Sears servicing center. However, warranty coverage may be denied if the small off-road engine or a part of it has failed due to abuse, neglect, improper maintenance, unapproved modifications, or the use of parts not made or approved by the original equipment manufacturer. To claim the warranty, the owner should present the small off-road engine to a Sears authorized repair center as soon as a problem exists. Warranty repairs should be completed within 30 days. For any questions regarding warranty rights and responsibilities, the owner should contact their nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.360120 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 352
