No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35628
Background
The Craftsman Chain Saw 358.356280 is a gasoline-powered saw. Manufactured by Poulan/WeedEater for Sears, it is designed to cut through wood. The saw includes features such as a reduced-kickback guide bar, low-kickback chain, handguard, spark arrestor, temperature limiting muffler, and a vibration isolation system. In addition to these, the saw also has front and rear handlebars that are designed in a way that provides balance and resistance if kickback occurs.
The chainsaw is equipped with a temperature limiting muffler and spark arresting screen which meet the requirements of several local and state regulations. The saw is designed for cutting wood only, and it is recommended to accelerate the engine to full throttle before entering the cut and to only cut at full throttle. The chainsaw is also designed for easy maintenance with provisions to check the guide bar, clean the air filter, and inspect the spark arrestor screen among other components. It is recommended to take the saw to a service center for a full clutch inspection after every 100 hours of operation.
Technical Specifications
  • Model Number: 358.356280
  • Product Type: Chain Saw
  • Engine: 2-cycle engine
  • Oil Requirement: Uses 2-cycle engine oil
Warranty
The Craftsman Chain Saw 358.356280 comes with a one-year warranty from the date of purchase. During this period, Sears will repair any defects in material or workmanship in the chainsaw at no charge, provided that the chainsaw is maintained, lubricated, and tuned up according to the operating maintenance instructions in the operator's manual. However, please note that the warranty does not cover expendable parts such as the bar, chain, spark plug, air filter, and starter rope, which may become worn during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies only for 30 days from the date of purchase. To claim the warranty service, you can return the chainsaw to the nearest Sears service center or department in the United States. It is important to note that this warranty gives you specific legal rights, and you may also have other rights that vary from state to state. For further information or assistance, you can contact Sears, Roebuck and Co. at Sears Tower, Dept. 698F/3_A, Chicago, IL 60684.
Craftsman 358.356280 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 390
