2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3519
Background
The Craftsman Chain Saw 358.351900 is a gasoline-powered chainsaw designed for cutting wood. The product was manufactured by POULAN/WEEDEATER for Sears under the Craftsman Brand. The chainsaw is certified under the American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-2000). The chainsaw comes with a cooling system to manage its working temperature. This cooling system consists of an air intake on the starter, air guide plate, fins on the flywheel, cooling fins on the cylinder, and a cylinder cover that directs cold air over the cylinder.
The chainsaw also features a chain brake, an air filter, a spark arresting screen, and a muffler. The chain brake is a safety mechanism to stop the chain from spinning. The air filter is designed to keep dust and debris out of the engine to improve its lifespan and performance. The spark arresting screen is designed to prevent sparks from exiting the muffler, thereby decreasing the risk of starting a fire. The muffler helps to reduce the noise produced by the engine and direct exhaust gases safely out of the engine.
Technical Specifications
  • Model Number: 358.351900
  • Product Type: Gasoline Chain Saw
  • Engine: 2.6 cu.in./42cc 2-Cycle
  • Bar Length: 18 in.
  • Cooling System: Equipped with air intake on the starter, air guide plate, fins on the flywheel, cooling fins on the cylinder, and a cylinder cover
  • Air Filter: Requires cleaning after 10 tanks of fuel or 5 hours of operation, whichever comes first
  • Muffler: Contains a spark arresting screen that requires cleaning every 25 hours of operation or annually, whichever comes first
  • Chain Brake: Included
  • Throttle Trigger: Included
  • Primer Bulb: Included
  • Emissions: Meets the standards for small off-road engines, certified as emissions compliant for moderate (50 hours) use
  • Additional Features: Includes a front hand guard, front handle, ON/STOP switch, choke/fast idle lever, and a rear handle.
Warranty
The Craftsman Chain Saw 358.351900 comes with a warranty that covers defects in material or workmanship for a period of two (2) years from the date of purchase. If the product fails within this warranty period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, if the product is used for commercial or rental purposes, the warranty period is reduced to 90 days from the date of purchase. It's important to note that the warranty only covers defects in material and workmanship and does not cover expendable items such as bars, chains, filters, or spark plugs that can wear out from normal use. Additionally, the warranty does not cover repairs necessary due to accidents, failure to operate or maintain the product according to instructions, preventive maintenance, or repairs due to improper fuel mixture or contaminated fuel. To claim the warranty, simply return the product to a Sears store, Sears Service Center, or other Craftsman outlet in the United States.
Craftsman 358.351900 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 29
All Time: 315
