2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35182
Background
The Craftsman Chain Saw 358.351820 is a gas-powered chainsaw designed for cutting wood. It is equipped with a 2.4 cubic inch/40cc 2-cycle engine and an 18-inch bar. The chainsaw is manufactured by Poulan/WeedEater for Sears under the Craftsman brand, and it utilizes a fuel mix for operation.
Key features of the chainsaw include an ON/STOP switch, a throttle trigger, a choke/fast idle lever, a primer bulb, and a chain brake. The ON/STOP switch is used to stop the engine, while the throttle trigger controls the engine speed. The choke/fast idle lever aids in cold starting or after refueling by providing additional fuel to the engine. The primer bulb circulates fuel to the carburetor for quicker starting. The chain brake is designed to stop the chain if kickback occurs, which can be activated either automatically or manually. Furthermore, it is normal for a new chain of this product to stretch during the first 15 minutes of operation, which suggests that users should check the chain tension each time before starting the chainsaw.
Technical Specifications
  • Model Number: 358.351820
  • Product Type: Chain Saw
  • Engine Type: 2.4 cu.in./40cc 2-Cycle GASOLINE
  • Bar Length: 18 in.
  • Equipped With: Chain Brake
  • Features: Anti-vibration system
  • Equipped With: Spark Arresting Screen
  • Compliance: Certified to be emissions compliant
  • Additional Feature: Chain tension check system
  • Additional Feature: Automatic chain brake activation in event of kickback
  • Additional Feature: Primer Bulb for quicker starting
  • Additional Feature: Choke/Fast Idle Lever for cold starting or after refueling
  • Additional Feature: Throttle Lock-Out to prevent accidental trigger squeeze
  • Additional Feature: ON/STOP SWITCH for stopping the engine
  • Additional Feature: Chain Catcher
Warranty
The Craftsman Chain Saw 358.351820 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may occur within two years from the date of purchase. If the product fails due to such defects, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, if repair is not possible. However, it is important to note that the warranty does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that can wear out within a year. Additionally, the warranty is only valid for 30 days if the product is used for commercial or rental purposes. To claim the warranty, you can contact your nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.351820 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 34
All Time: 546
