2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.351701
Background
The Craftsman Chain Saw 358.351701 is a gasoline-powered chainsaw that was manufactured by POULAN/WEEDEATER for Sears. The chainsaw features a 2.3 cubic inch/38cc 2-cycle engine and a 16-inch bar. It is equipped with a system to keep the working temperature as low as possible, which includes air intake on the starter, an air guide plate, fins on the flywheel, cooling fins on the cylinder, and a cylinder cover that directs cold air over the cylinder. The chainsaw is also equipped with a chain brake and a choke/fast idle lever.
The chainsaw is designed to run on a minimum of 87 octane [R+M]/2 clean gasoline. The chainsaw operates by pulling a starter rope handle, which can be done with a controlled and steady motion, thanks to its Sim-pulTM starting system. It also comes with a primer bulb that needs to be pressed slowly six times to start the engine, and a choke/fast idle lever that sets the correct throttle setting for starting when pulled out to the full extent. The chainsaw is also equipped with an ON/STOP switch for easy operation.
Technical Specifications
  • Model Number: 358.351701
  • Product: Craftsman Chain Saw 358.351701
  • Product Type: Chain Saw
  • Cooling System: Equipped with air intake on the starter, air guide plate, fins on the flywheel, cooling fins on the cylinder, and a cylinder cover
  • Chain Brake: Must be disengaged before cutting with the saw
  • Fuel Requirements: Requires the use of minimum 87 octane clean gasoline
  • Starting Position: Saw must be held firmly on the ground with chain free to turn without contacting any object
  • Engine: 2.3 cu.in./38cc 2-Cycle Gasoline Engine
  • Bar Length: 16 inches
  • Air Filter: Needs to be cleaned after 10 tanks of fuel or 5 hours of operation, whichever comes first
  • Muffler: Contains a spark arresting screen that needs to be cleaned every 25 hours of operation or annually
  • Ignition Switch: Has ON and STOP positions
  • Parts: Comes with 2-cycle engine oil and a carrying case
  • Standards: Listed by Underwriters Laboratories, Inc. in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-2000)
  • Assembly: Comes fully assembled
Warranty
The warranty for the Craftsman Chain Saw 358.351701 is valid for two (2) years from the date of purchase. This warranty covers any defects in material or workmanship during this period. If the product fails due to a defect, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement. However, please note that the warranty only applies for 90 days if the product is used for commercial or rental purposes. The warranty specifically covers defects in material and workmanship and does not cover expendable items that can wear out from normal use within the warranty period, such as bars, chains, filters, or spark plugs. It also does not cover repairs necessary due to accident or failure to operate or maintain the product according to the supplied instructions, or preventive maintenance or repairs due to improper fuel mixture, contaminated or stale fuel. To claim the warranty, simply return the product to any authorized Sears or Craftsman outlet.
Craftsman 358.351701 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 57
All Time: 883
