No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35099
Background
The Craftsman Chain Saw 358.350990 is a gasoline-powered saw designed with a 2.6 cu.in./42cc 2-Cycle engine. The saw comes with an 18-inch bar, which is designed for cutting through various types of wood. The saw is equipped with features such as a choke for easy starting, a front hand guard for protection, and a muffler to reduce noise and direct the exhaust away from the user.
The chain saw also features a primer bulb for starting the engine and a throttle lockout to prevent accidental activation of the throttle trigger. It has a chain brake that can stop the chain in case of a kickback. The saw also features a fuel mix fill cap and a bar oil fill cap, which allow for the addition of gasoline and bar oil, respectively. Additionally, the chain saw has a cooling system to maintain an optimal working temperature during use, and an air filter to keep debris and dust from entering the engine.
Technical Specifications
  • Model Number: 358.350990
  • Engine: 2.6 cu. in./42cc 2-Cycle gasoline engine
  • Fuel Requirements: Minimum 87 octane clean gasoline. Do not use ethanol blends over 10%.
  • Bar Length: 18 in.
Warranty
The warranty for the Craftsman Chain Saw 358.350990 is valid for a period of two (2) years from the date of purchase. This warranty covers any defects in material or workmanship. If the product fails within the warranty period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, please note that this warranty only applies for 90 days if the product is used for commercial or rental purposes. It is important to follow the operator's manual for proper use and maintenance to ensure warranty coverage. To claim the warranty, simply return the product to a Sears store or service center. It is advisable to keep the purchase receipt as proof of purchase.
Craftsman 358.350990 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 328
