7 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35088
Background
The Craftsman Chain Saw 358.350880 is a gas-powered chainsaw designed for cutting wood. It is manufactured by Poulan/Weedeater for Sears under the Craftsman brand. The chainsaw is equipped with a variety of elements aimed at enhancing its functionality and ease of use. Among these are the On/Stop Switch used to control the engine, a Throttle Trigger that manages the engine speed, and a Throttle Lock-Out ensuring the trigger can't be squeezed accidentally. It also features a Choke/Fast Idle Lever which contributes to quicker starting in cold conditions or after refueling and a Primer Bulb designed to circulate fuel to the carburetor, facilitating quicker starting.
The chainsaw comes with a Chain Brake mechanism designed to stop the chain in case of kickback. The brake can be activated manually or automatically. The chain tension is adjustable and it is normal for a new chain to stretch during the first 15 minutes of operation. The chainsaw is also equipped with a Clutch Washer and a Clutch Drum, among other parts. The product comes fully assembled and has been factory tested with the carburetor precisely adjusted for optimal performance.
Warranty
The warranty for the Craftsman Chain Saw 358.350880 is a one-year full warranty. If the product experiences a defect in material or workmanship within one year from the date of purchase and is used and maintained according to the operator's manual, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, it is important to note that certain parts such as the bar, chain, spark plug, and air filter are considered expendable parts and are not covered by the warranty. The warranty also applies for only 30 days from the purchase date if the product is used for commercial or rental purposes. To file a warranty claim or for any questions regarding warranty rights and responsibilities, it is recommended to contact the nearest authorized service center or call Sears at 1-800-469-4683.
Craftsman 358.350880 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 712
