2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35083
Background
The Craftsman Chain Saw Model 358.350830 is a gasoline-powered tool designed for cutting wood. Manufactured by Poulan/Weedeater for Sears, this chain saw runs on a 2-cycle, 2.4 cubic inch (approximately 40cc) engine. Its main components include a front handle, starter rope, on/stop switch, choke/idle lever, muffler, bar, sprocket hole, starter housing, fuel mix fill cap, primer bulb, cylinder cover, chain, throttle lockout, rear handle, clutch cover, and bar nuts.
The chain saw also features a chain brake, designed to halt the chain's motion in the event of a kickback. The chain brake can be activated both automatically and manually. For optimal performance, the chain tension should be checked frequently, particularly as a new chain is prone to stretching during the initial 15 minutes of operation. The choke/fast idle lever controls the additional fuel supply to the engine during cold starting, while the primer bulb facilitates quicker starting by circulating fuel to the carburetor.
Technical Specifications
  • Product Type: Chain Saw
  • Model Number: 358.350830
Warranty
The warranty for the Craftsman Chain Saw 358.350830 is valid for one year from the date of purchase. If the product fails due to a defect in material or workmanship within this period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, please note that the warranty excludes the bar, chain, spark plug, and air filter, as these are considered expendable parts that can wear out in less than one year. Additionally, the warranty is only applicable for 30 days from the purchase date if the product is used for commercial or rental purposes. To claim the warranty, customers should contact their nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.350830 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 39
All Time: 540
